2010 Streetglide Speakers Shot
I went from stock to hogtunes which was little upgrade, then Boom Audio was was more improvement and now am using Polk Audios MM651's backed with a Rockford Fosgate PBR300X2 amp. Sound is very very good. The Polks can be had on Amazon for around $130 a pair and you would need Adapter rings for around 40 or 50 bucks from Dragonfly.
If the head unit is still good some infinity/JBL 2 ohm coax 6.5 and adapters is good bang for the buck. Polk mm651 are better. Adding a Rockford Fosgate pbr amp to the polks is a nice setup. Biketronics 7.1 Titans with the amp is better.
If the head unit went south there are lots of great options in the aftermarket.
Check out the audio section. Good Luck!
