2013 Ultra's Rear Seems High
The back end of my new Ultra seems to high in the rear and I only have about 15 psi in the rear shocks. I would like it to sit more level or even a bit lower in the rear. I was wanting to know if the HD Premium Ride Hand-Adjustable Rear Shocks pt # 54680-10 would be an easy way to address this situation. I believe they are the stock rear springs on the new 2014 street glide special. Also would I have to do anything to the front shocks if I installed them?
the amount of air pressure in your shocks does not raise or lower your rear end.
those shocks would work fine, and no, you don't have to lower the front end. that would give you the same setup as you would get if you got a street glide or roadglide custom.
there are other options out there that you could go with if you are willing to spend $500. if you can get them used or heavily discounted, i would go with them. if you're paying full retail, do some more research. motorcyclemetal.com is a good place to start.
gsb8858
07-05-2018 11:12 AM
