FL-Vied-10 INSTALLED!
Not an indepth technical thread at all, but as far as the Vied install, it was a simple snap in and screw down procedure. BIG BIG thanks again to bg1 for the parts! can't thank him enough!!
all i have on the Ultra Classic is a set of gutted Road Glide pipes (slightly larger than stock and gutted), set the dial to 50% and we'll see how it goes....
initial drive to work after install.....
i usually ride to work the same route.... one hill always produced a ping in 6th gear at 60mph (obviously cause it is under a load and uphill), tried mid grade fuel, and high grade, still ping... even had a slight ping with factory plugged up pipes. read where the 103 ping was pretty common.
today on the same route, at 60mph there was no ping. i even turned the radio down to see if i heard it. no ping. can't really say if there was more throttle response, it livened up a good bit with a more open exhaust anyway.
so as far as the results... seems decent to me, and when i called the dealer this afternoon, talked to the service manager (who was originaly the salesman who sold me the bike), he said i was good to go as long as no wires were cut or spliced to add the component. if it's "plug n play" or "bolt on" the warranty remains in tact! awesome dealer!!
Cool
I have them on my 2009 with slip ons....My question has always been How do I know they are working ? If you think or know you can't hear ping then I guess that is something...I really never had ping just wanted to see if run better and cooler? But I don't know if I have that. keep us posted !
Hap
Hap
