Want some clunck gone
I have 5k on bike. Its a 13 UC. Changed trans and primary oil at 1k to HD transmission primary oil. Why is there suck a loud clunk when shifting were does the sound really come from and how do u get rid of some of the noise. Some bikes seem louder than others. Mine is loud. has been loud from day one compared to my other bikes
there will be some clunk ( shoulda heard my '74 BMW!)
it is all about the design of the tranny and the way the gears are cut.
as long as you have quality lube ( I use the HD) in the correct quantity ( overfilling will cause oils to foam- and the foamy oils do not lubricate as well.
a heavier lube may quiet down the tranny- BUT it will also eat power...this is a balancing act
You might have a look at the clutch adjustment- if the clutch is not full disengaging, shifting will be rougher
mike
mike
Harley 6-speed transmissions are knows as "clunk shifters" in some circles. Some more than others. If you are getting what you think is excessive clunk your next chore should probably be to check the clutch adjustment in the primary case. They will all clunk loudly when going from neutral to first, but if the clutch is properly adjusted it should shift much quieter when going upward through the gears. Otherwise upshifting could be pretty noisy and annoying.
