21" tire rubbing even when drilled the fender holes?
I bought some new tires for my bike i originally had metzler but now switched to pernelli and now my front tire rubs even when i drilled the fender. Melted the paint on my fender Should i just drill the fender out some more ? Anybody have pics of the fender holes after you drilled them? Whats best to use a regular drill bit or a dremel to shave it off? I like the look of the stock fender and would like to keep it.
I had an Avon Cobra originally on my 21" front wheel. I drilled the rear mounting holes on the front fender before installing the wheel and the Avon tire. When I first put it on and I had the bike on the jack I spun the front wheel and I could hear the "new tire hairs/nipples/fingers" (whatever you call them) rubbing against the inside of the fender. I recently replaced the tire with a Metzler and did the same thing, but the tire hairs did not touch the fender. I guess the Metzler's are slightly smaller in diameter.
OK, WTF??? I may need some help from you guys to talk me down off the ledge!
I am staring here at my brand new 21 inch wheel with Vee Rubber tire. I was under the impression that a 21 wheel and tire were a 100% direct bolt on, and now you guys are talking burnt paint and drilling fender mounts. Please elaborate. I was literally on my way downstairs first thing in the morning to install this wheel, now I'm in a panic.
Please advise.
Please advise.
