Auxillary Switch Housing Question
I am considering buying an auxiliary switch housing, HD part number 70248-02B. There are 3 others (chrome, left, right, etc.): 70255-02B, 70256-02, 70213-02C. I would like to install various switches in it for use with a garage door opener, SIRI activation, etc. These would require a "momentary" switch action. The only switch I've been able to find that fits the housing is an on-off switch, part number 71718-02.
Does anyone know of other HD switch part numbers that fit this housing? I've looked through the P&A catalog, but all it says is "switches sold separately". My Googling has produced no viable candidates either.
Any help would be greatly appreciated!
Rob98208
Rob98208
figure out what you'd like to do- the end result and you can then approach each.
the simplest thing to do with a garage door opener is to replace the opener switch with a relay.
wire the relay so that it goes "on" with the high beam or horn...you just flick the high beam and "Open Sesame"
takes minutes
there are other easy solutions to just about anything you might want to do, especially if you use relays to have 1 function control a secondary added function.
I even know a couple of guys who use switches mounted on the floorboards...
Mike
takes minutes
Mike
MKGUITAR, excellent suggestion. I suspect this is how the Harley GD opener works, but this is a much cheaper solution.
bsnilloc, that would have been a good option, but all 4 lower switches are used in my Ultra Limited.
I was actually thinking of adding the HD 'Gear Indicator' (p/n 70900078, $182 at KutterHD) which would leave one empty slot for adding a momentary switch.
Thanks for both of your suggestions, Rob.
gear indicator is kinda a geegaw- but if you need it...
the "diy mods and tricks" sticky is handy
https://www.hdforums.com/forum/touri...s-to-save.html
mike
mike
Thanks again, Rob.
on late models the wiring all runs through a trough.
remove the tank, the fuel connector is like an air hose...push up on the metal collar and the fuel line drops down- depressurize system first by letting sit overnight, or run bike and pull fuel pump fuse ( although this can throw a code).
some bolts, some plugs
lift the tank off, pop open the trough.
I have some air horn wiring, headphone jack, alarm wires and have laid in a couple of extra connectors for future projects.
takes minutes- easier with less gas in the tank.
mike
mike
