2009 SG steering/ tracking questions
As mentioned above I have an 09 SG. It seems to me when I ride my GF's 09 SG and other friends touring bikes...there bikes track or feel tight and straight....its like the bike is riding in a rail....it feels very stable...my bike feels loose up front...its opposite of others I've ridden...it feels unstable and definitely not riding in a straight rail.
Not sure if I'm describing it correctly but it just seems the front is more stable on other touring bikes.
The only difference between my bike and others I've ridden is...
I changed the front & rear tires and wheels to 18", front forks were swapped put for powder coated ones, different handlebars. I'm thinking maybe the bike isn't aligned correctly. I've heard about this neck bearing problem too...not sure if it would effect the " tracking" of the bike...
Any ideas???
Thx
Any ideas???
Thx
No mention in your post about tire pressure or shock pressure. Since you are running different wheels and tires, the owner's manual pressures don't apply any more. Try to find the tire manufacturer's recommendation for your bike or go with the max cold pressure on the sidewalls.
Also no mention of the wheels and tires on the other machines you liked better. There are plenty of complaints from guys with non standard wheel sizes regarding steering and handling. If they ever get it worked out, they don't seem to report what fixed the problem. Did you save your old wheels?
By putting 13" shocks and an 18" rear wheel you have raised the the rear end about 1 1/2". This will steepen the head (steering neck) angle. Resulting in quicker steering with less caster. Caster makes the wheel track strait.
You have also raised you center of gravity, that does not help either.
Or leave the 18" up front and go with the stock size tire/wheel combo of 16" in the rear?
Wow a lot to think about!!!
