HELP....I'm no mechanic
Old 09-02-2013 | 08:09 PM
09B29's Avatar
09B29
I would bet your exhaust header nuts are loose
check em but DO NOT Overtighten
Old 09-02-2013 | 08:10 PM
fatboy1017's Avatar
fatboy1017
Everything is tight that I checked, actually filled up with new gas on my way home from Pittsburgh, and it does not do it at idle, just under half or more throttle. I didn't idle for 2 hours, I was in and out of heavy traffic with periods of idling for 2 hours.
I'm gonna call in the morning, just bummed out about it. It is a new sound that developed on Saturday, wasn't there in the 1st 11,250 miles. Thanks guys, i'll let you know what they say.
Old 09-02-2013 | 08:14 PM
ColoFXDC's Avatar
ColoFXDC
Originally Posted by BoonDock_Saint
If you find that it's detonation (which sounds like what your describing), I would sweat it until you fix it. While some pinging can be inconsequential, it can also lead to a catastrophic event. Could be fuel, timing, bad gas, a glowing carbon deposit.... That's what warranties are for right!? Let us know what they find!
Nope not true. The stealership told me that engine pinging/spark knocking/ detonation is "NORMAL" and doesn't do any damage to the engine when I brought my bike in for pinging. They wouldn't lie to me would they???
Install an oil cooler OP!!!!
Old 09-02-2013 | 08:22 PM
12hdrk's Avatar
12hdrk
Slight occasional ping under load would probably not be that harmful although I would try and get rid of it. Constant ping or more serious heavy detonation should be cause for concern. Internals are taking a beating over time.
Old 09-02-2013 | 08:46 PM
btsom's Avatar
btsom
Check both ends of the top cross brace/link at both ends for looseness. My son had an intermittent loud rattle and the frame end of the link had worked loose.
Old 09-02-2013 | 09:13 PM
ColoFXDC's Avatar
ColoFXDC
Yeah that's true. I thought it was BS when the stealer said they come lean from the factory, but after seeing the blueing and discoloration of the pipes under the heat shields, they might be right. If the ECM programming was correct and the engine temperature was regulated, I doubt you'd get any pinging at any time. And I personally believe we shouldn't have to accept that as "normal".
Old 09-02-2013 | 09:42 PM
SpiderPig's Avatar
SpiderPig
Check the exhaust bracket that holds the pipe that goes under the frame. Mine was loose today and caused me a concern as well. Had to tap with a hammer to tighten the bracket. Th bolt was tight but the pipe was able to rattle in the clamp still.
Old 09-03-2013 | 09:57 PM
fatboy1017's Avatar
fatboy1017
Red face
I was totally off base....my problem was the exhaust pipe coming off the rear jug was missing the bolt at the top. 5 minute fix and I was on the road. Mechanic said the 103 is practically bullet-proof knew it wasn't a motor issue! 2 days of stress and worrying for nothing. I swore it was coming from the front jug!
Old 09-03-2013 | 10:48 PM
texaswiz's Avatar
texaswiz
He said the 103 was what? "Bulletproof you say".
Old 09-03-2013 | 10:57 PM
CSMHOG's Avatar
CSMHOG
Glad is worked out and it's running right. I would hardly say the 103" is bullet proof, although I wish it were.
Quick Reply: HELP....I'm no mechanic
