Bag 09' Street Glide - Unfortunate Incident
My right side bag fell off while on the highway the other day. My fault but I have a hard time believing the pins weren't in as, without them, the bags fall off standing still. The bag would have fallen off prior to getting on the highway.
Vibration loosened the pins?????? I don't know. I could speculate all day long.
Anyway, just looking to see if anybody else might have had a similar incident and also wondering if there's a better locking mechanism (other than wrap around bars) to keep the bags secure.
Haven't had the experience myself, but there are several here on the forums that have - improper installation and sprung dzeus clips seem to be the biggest contributors. There are several methods to make the mount more secure; Brukus is a forum sponser that sells a kit for around $25.00, or you can go with any of the several hardware store methods posted around the forum.
I can only imagine the sinking feeling when you look back and see a bag missing. I hope the damage wasn't too bad and that you can get your scoot back up to snuff without too much drama.
the stock pins may spread over time or vibrate out- and recent posts about theft drive a frenzy.
at the very least tie a shoelace between the rings to keep the pins from rotating out- either from vibration, or a bad guy working the slot with a screwdriver tip
or
your local home depot is a source for an easy preventative fix for under $10
Crown Bolt #43228 speed nut (SMS type U 5/16-18 thread )
Crown Bolt #66808 wing bolt ( 5/16-18 thread X 1" ) if you don't want a wing bolt, then use a bolt
a couple of rubber fender washers too, or reuse the stock ones
if theft is prime mover, replace the 1/4" bolt of the FRONT saddlebag mount with a button head type which cannot easily be turned out with visegrips
for models with saddlebag guards, a strip of rubber on the inside of the guard, will keep you bag from being scratched when taking the leftside bag off and putting on
and rubber stick on feet on the bottom of the saddlebags, allows you to put the bag down anywhere without looking for a soft spot...I found myself standing there with bag in hands, looking for a towel of something on the floor.
OP, welcome to the forums- the are a few areas of common concern, this is one of them...another is IF you have an alarm system SET and KNOW the PIN for the day when your fob is lost or the fob battery dies.
mike
or
mike
I bought a inexpensive kit on e bay, clips with threads and allen screws, I almost lost one once, these stay secure and makes it much harder to steal. This is the link
http://www.ebay.com/itm/BAGGER-LOCK-...#ht_1800wt_917
FYI: Just overnighted a set of SaddlebagSecure to a new customer who was stopped at a Loaf and Jug gas station at Route 160 and Route 17 in Alamosa, CO - while traveling from Santa Fe, NM to Breckenridge, CO. In the 3 minutes this biker was inside using the facilities and purchasing a bottle of water - the bag was gone.
"I am more than happy for you to post about the incident. I hope that I have sold several sets of SaddlebagSecure for your company!"
