I did the V&H fuel pac thing and it went bad!
Old 09-01-2013, 05:10 PM
Hogster 1's Avatar
Hogster 1
Hogster 1 is offline
Exclamation I did the V&H fuel pac thing and it went bad!
I was suckered in...I thought that the Vance and Hines fuel pac was all that you need for a Harley, with slipons, and an free flowing air filter...That WAS probably true. It worked pretty well for me in that capasity (sp) Untill I went to the coast. I had troubles there. My bike would hardly run. It did soon clear it self up... but it was dicy there for a few minuets.
They (Vance and Hines) sold me on the fact that they could dial in my cams also....Apparently they were wrong. After 8 calls to them to correct my problems...I still have rideabiltiy problems. In their defence... they did solve most of my troubles..Which made calling them easy..but toward the end... they were saying that it was the cam that I have, and the chaertoristics (sp) and they were at the end of their experience. My last problem was...leaning out on throtle at 2300 rpms at 65 mph in 6th gear, and trying to climb as hill and it backfiring and seeming to run on one cylinder. And that anytime I rolled on the throttle, in a higher gear, then it seemed to accellerate a little bit, and then the more throtle I rolled on then it would loose speed and start to spit and sputter. When I told them this ...they are at a loss...and aparently I am too.
I am looking for a thundermax if anyone has one to sell...
Old 09-01-2013, 05:35 PM
mkguitar's Avatar
mkguitar
mkguitar is offline
I my self wouldn't try running up a hill in 6th at 65 MPH.
I will go into 6th at 65 MPH on flat ground with no headwind.
I find the motor works better closer to 3000 rpms.
Mike
Old 09-01-2013, 05:43 PM
Herksuper's Avatar
Herksuper
Herksuper is offline
With engine work, you would probably be better off with a dyno tune. I didn't think V&H fuelpack had the versatility of other tuners when it came to anything other than the typical A/C and pipe change.
Old 09-01-2013, 05:53 PM
mgmmgm's Avatar
mgmmgm
mgmmgm is offline
Call Fuelmoto and see if they can get you set with a tuner?
Old 09-01-2013, 06:24 PM
HDV-GLIDE's Avatar
HDV-GLIDE
HDV-GLIDE is offline
Fuel Paks are good for slip-ons and high flow filters. I ran one in the beginning, you could smell the richness through the pipes. It did work to some extent but will never take the place of a real tuner. Fuel Moto was buying back these things for $125 I believe in the past if you bought another tuner from them, maybe they still are....
Old 09-01-2013, 07:53 PM
ftworthcowboy's Avatar
ftworthcowboy
ftworthcowboy is offline
Mike
Old 09-01-2013, 08:04 PM
1BRAVO9's Avatar
1BRAVO9
1BRAVO9 is offline
You might have just discouraged me from getting one.
Old 09-01-2013, 08:23 PM
BLKPRLFLHTCU's Avatar
BLKPRLFLHTCU
BLKPRLFLHTCU is offline
I have never met anyone with a bike that has O2 sensors on it that tuned there bike properly with a fuelpack. I wouldn't think that the new cams would help matters any.
Old 09-01-2013, 08:40 PM
sniperduce's Avatar
sniperduce
sniperduce is offline
Hi, my 08 has O2 sensors with a FP for 30K miles so far no issues.
Old 09-01-2013, 08:58 PM
Hogster 1's Avatar
Hogster 1
Like I and others have pointed out...Fuelpacs are ok if you are only going to do minor mods,...I have one for sale... Would you be interested? I kinda passed the minor mod,,,,
Quick Reply: I did the V&H fuel pac thing and it went bad!
