Trans shifts hard should i be concerned?
Hello, I have noticed that my bike (2013 Limited) is shifting a little harder than usual. I recently adjusted the clutch and did everything by the service manual. I turned the adjuster screw almost 1 full turn out (I like my engagement point close to the grip) and adjusted proper amount of free play at the lever. I have noticed when shifting through all the gears and downshifting there is a clunk like when you first change into first from neutral. I can find neutral very easy and there is no lurching with the clutch lever pulled in while in gear. I just want to make sure I am not doing any damage. I am running the Spectro 6 speed trans fluid.
Thanks very much!
Thanks very much!
have a look at the clutch again.
you first adjust the clutch to spec so that it cleanly engages and disengages in operation
you then use the cable adjuster to fiddle with the cable play and can also affect the lever pull
often hard shifting is a indicator of clutch or primary chain mal-adjustment.
the ez pull clutch mechanism used since 2007, does not allow as much latitude in lever pull adjustment as earlier models if that is what you are used to... the easier pull is due to a longer lever pull
Mike
Mike
Thanks, I will look at the clutch again but if I re adjust it I would do everything the same since I went step by step in the manual. As I said above the same clunk when shifting from neutral to first is heard when shifting through all the gears. It seems to be worse when downshifting.
Thanks
Thanks
Thanks
Thanks
You report neutral is easy to get, that suggests a properly adjusted clutch. The clunk going into gear from neutral could suggest a slight dragging clutch HOWEVER it is a characteristic of a wet clutch to have some viscous drive even when the plates are separated. If you are going inside the derby cover one more time, how do you feel for the contact point when adjusting the hub screw? Several times I felt for the resistance point using finger pressure on a socket drive allen wrench. What I felt, rather than the contact point, was a rough spot in the threads, not the real contact point. I now turn the screw in and out several times using a wrench handle to smooth any burrs in the threads, then feel for the contact point by hand and then set the adjustment. I also found that my intuitive lock nut torque was well beyond the book value. I now tighten the lock nut with a torque wrench. Even with a properly adjusted clutch, the only time I don't get the clunk going into first from neutral is on the first start of the day if I pull in the clutch lever prior to start and hold in until ready to move. The cool lube in the transmission provides enough drag to keep the driven half of the clutch from spinning and the transmission drops into gear silently. The rest of the day, even following the same procedure, I get the clunk, that seems to be the nature of the beast. You are already using one of the 2 most highly recommended transmission lubes, so that isn't the problem.
Thanks very much!
Thanks very much!
Mark
Thanks, I had to turn the adjustment screw in a few times with a wrench also because I was running out of threads on the lever adjustment shaft. I turned the adjustment screw in a good bit a few times, then set the adjustment by hand and it seemed to solve the issue.
Are you saying I may have to much primary fluid in the bike?
I am going to start over with the clutch adjustment. I love where it releases with 1 full turn out but I think I will set it at 3/4 turns.
Thanks a lot!
I'm gonna try the clutch once more and if that doesn't fix the problem I guess the fluid is the only other option.
