Question about the *running lamps staying on with bright light* kit.
Old 09-01-2013 | 11:33 AM
redneck0372's Avatar
redneck0372
I just turned the forks to the left, but when I did the bars on the bike I moved the harness so I could just reach it.
Old 09-01-2013 | 12:10 PM
desertclassic's Avatar
desertclassic
Easy, I had to pull the fairing on the 07 ultra. Took longer to find the zip ties than it did to do the job.
Old 09-01-2013 | 01:11 PM
fat daddy's Avatar
fat daddy
I wired to the acc switch and you can turn em on or off at will no mater what beam the headlight is on
Old 09-01-2013 | 01:34 PM
baust55's Avatar
baust55
HERE is link to other thread free mod without harness ...doesn't say weater it works with road king.
https://www.hdforums.com/forum/touri...ee-w-pics.html
Old 09-01-2013 | 02:01 PM
Weavr99FLHT's Avatar
Weavr99FLHT
if you already have the $30 "harness", you may be able to reach it by turning the handlebars to the left, find the wires underneath the "cap" (where the switches are) trace the wires with your fingers until you can find the plug. I was able to find the plug but not enough room to be able to work (not enough slack in the wires). So I pulled the outer fairing off. I've pulled the outer fairing off so many times it doesn't bother me at all when I realize, for whatever reason, i need to do it.
Old 09-01-2013 | 03:00 PM
mgmmgm's Avatar
mgmmgm
i got the HD plug and play for this for about $30.00 now if I can just find it on the work bench........ have not been in a rush to do this. Will give it a go before my next long distance tour though.
Old 09-01-2013 | 04:28 PM
GAZippoman's Avatar
GAZippoman
Default Wiring Mod Vs harness
I took the fairing off to plug in the harness. Did the install when I had the fairing off to install new speakers and an amp.
As to the wiring mod to the aux switch, problem with that mod is you if you turn off your aux switch to turn off aux lights, you can't use other items (like heated vest or anything else).
Quick easy and $30 is cheap
Old 09-01-2013 | 05:12 PM
Ultra-Rick's Avatar
Ultra-Rick
Originally Posted by SBates08
Unless your just wanting to spend the money, that kit isn't necessary. If you'll search these forums you can find detailed instructions and pics on how to do this for free by only swapping 2 wires around.
Here's a wiring diagram and a couple of pics of what wire needs swapped.
It takes all of about 30 minutes o complete. Only the switch assembly has to be removed. And best of all it's free.
Attached Thumbnails Question about the *running lamps staying on with bright light* kit.-passing-light-mod.jpg   Question about the *running lamps staying on with bright light* kit.-spot-light-mod-1.jpg   Question about the *running lamps staying on with bright light* kit.-spot-light-mod-2.jpg
Old 09-01-2013 | 06:25 PM
Airborne350G's Avatar
Airborne350G
Too bad it is illegal to have the spots on and high beams here in Virginia.
Old 09-01-2013 | 06:46 PM
1st 96 ultra's Avatar
1st 96 ultra
I just used the power wire from the acc switch to the spot light switch so I am still using the right switch , if you can do some basic wiring , you have to take the outer fairing off any way so why waste the money on the plug kit . if you can't then the kit is just plug and play , but good mod either way
Quick Reply: Question about the *running lamps staying on with bright light* kit.
