HELP !! smartphone mount wanted
Old 08-29-2013 | 06:13 AM
Jetblack3's Avatar
Jetblack3
Default HELP !! smartphone mount wanted
Just upgraded to a smartphone and have tons of music downloaded. Next thing I need is a mount so I can plug in and enjoy the tunes while cruising down the road. Would like some suggestions on what seems to work well whether it be handlebar mounted or some other way on the fairing ? It's a Motorola M android
Old 08-29-2013 | 06:28 AM
Geezr Glidr's Avatar
Geezr Glidr
I got a handlebar mount from Ram Mounts, and it was great. I've had 2 of them. I now have a head unit where the Ipod goes right inside, so I don't use RAM anymore. Google it.
Old 08-29-2013 | 06:51 AM
danzio's Avatar
danzio
I've tried several and the X-Grip from RAM is by far the most functional of all. It isn't the best looking, especially when empty but I'm more function over fashion anyway.
Old 08-29-2013 | 07:19 AM
Big Boz's Avatar
Big Boz
I went cheap for now.
I took 3 zip ties, 2 around the left bar but not tight. Slip the 3rd under both of those but don't tighten it up yet. You can now tighten up the first 2. I had an extra holster for my phone and slid the belt clip behind the 3rd zip tie and tightened that as I flattened it as well. Zip tie #1 & 2 slid inward about the same width as the belt clip. The only way the holster will come off is if I either break the zip ties or spread the 3rd zip tie with a flat blade screwdriver. Make sure the zip tie bracket is high enough on the bar so that if you have to make a full lock turn, the holster doesn't hit the tank.
Old 08-29-2013 | 07:40 AM
tOSUSteve's Avatar
tOSUSteve
+1 X-Grip allows different devices to be mounted using the same attachment.
Old 08-29-2013 | 08:17 AM
RollaMo's Avatar
RollaMo
Although not "cheap", it is very good quality.
http://www.ridersclaw.com/
Attached Thumbnails HELP !!  smartphone mount wanted-p3160060.jpg   HELP !!  smartphone mount wanted-p3160063.jpg
Old 08-29-2013 | 08:22 AM
Hogpro's Avatar
Hogpro
Former Sponsor
Iron Aces mount is the cleanest around.
http://www.ironacesspeedshop.com/pro...-gps-mount.cfm
They make a different one for the Road Glide. Since you didn't say what your bike is I assume you have a bat wing.
Old 08-29-2013 | 08:23 AM
oneballz's Avatar
oneballz
+1 Riders Claw!!
Old 08-29-2013 | 09:00 AM
03electraglide's Avatar
03electraglide
+2 on riders claw nice quality. ..
Old 08-29-2013 | 09:14 AM
Talldog's Avatar
Talldog
Here's what I'm using from RAM.
Amazon.com: RAM Mounting Systems RAM-HOL-UN4U Universal Finger Grip Holder: GPS & Navigation Amazon.com: RAM Mounting Systems RAM-HOL-UN4U Universal Finger Grip Holder: GPS & Navigation
The nice thing about these is they're adjustable for a lot of different phone sizes. And, if like me, you keep your phone in some sort of protective case, you can still make this work. It's not pretty, but it works very well.
Quick Reply: HELP !! smartphone mount wanted
