Vibration/Shaking fairing
Gents
so from about 1,800 RPM to 2,200 RPM i am experiencing quite a bit of vabration in my fairing, the bike has only 12k miles on it. it appears to do it no matter when i am increasing or decreasing in speed or even in neutral on the jiffy stand. Is this normal? I ask because this is my first Harley after coming over from a 1800VTX honda that ran smooth as silk. any info will be appreciated!
You could have broken fairing brackets. Pull the fairing off and check the brackets. There are 2 main brackets, one on either side of the radio. They are the ones most likely to break. Then there are 2 smaller horizontal brackets that run out to the speakers. These are less likely to break and cause a problem.
Check them again if you still have the fairing off. For the most part they break near the top of the fairing right below the bolts that go into the fairing. Sometimes as in my case it was not very noticeable at first glance.
so took it all apart for the 3rd time and checked, no cracks. i do however think i found the problem, If i am correct maybe everyone can confirm, i ran it without the front fairing on and obviously the windshield or fairng pouches and everything seemed fine. there was a little bit of resonance but nothing like before, when putting it back together i noticed the center top ferral for the windshield pulls out of the fairing when i tighten the screw down so im thinking what is happening is that this is in turn not getting sinched down which is allowing the actual windshield to vibrate as well as the pouch making the problem seem much worse than it is. so any way to repair that ferral?
