Vibration/Shaking fairing
Old 08-30-2013, 07:29 AM
blades11b's Avatar
blades11b
blades11b is offline
never mind! found the screw in type from some other guys on here. ill be picking some up today and giving them a shot!
Old 08-30-2013, 07:32 AM
soos's Avatar
soos
soos is offline
Here is a thread on the proper way to replace the insert.
Just a few notes though.
1. A tap really isn't necessary.
2. The insert is a self tapping type with the slot positioned as the leading end as pictured in the link.
Old 08-30-2013, 12:00 PM
timvan's Avatar
timvan
timvan is offline
Just put the ferrel in with some epoxy, use a windshield bolt to put it in the hole so that you dont get any epoxy on the threads.
Easy cure, wont prematurely pull out again..
Old 08-30-2013, 12:16 PM
Biker John's Avatar
Biker John
Biker John is offline
Default Interesting
I just heated mine up with a hot air gun. Also had one of the faring screws...Screwed into the faring nut...whatever...and then slowly screwed it in with the slot facing down.
Better than super glue IMHO...but now I have another reference to look back on in the future. Thumbs up...and yes the fairing brackets do break or crack.
Old 08-30-2013, 05:04 PM
Rickgyver's Avatar
Rickgyver
Rickgyver is offline
My Ultra fairing did same and I found two bolts missing at bottom/inside near cigg lighter next to fork legs. Problem gone !I believe they are 1/4-20. If you have batwing there are 4 bolts on backside.
Old 08-30-2013, 05:24 PM
katobird's Avatar
katobird
katobird is offline
MY R/H main black one just broke the other day..
It sounded like I hit a rock on the fairing...
Got home thought it was a rock looked for nick in the fairing..... clean
After more inspecting
I could move the Fairing at the speaker area a good 1-2 inches back and forth.
Took off the fairing and it broke right at the 90 degree at the top mount..
Clean break looked like a shear did it..
Welded it and backed it up with a .020 stainless angle
russl179
07-29-2008 11:55 PM
monkish
05-19-2007 07:44 PM
sortasuave
02-28-2007 05:10 PM
yota
09-29-2006 11:17 AM
jsm562
09-11-2006 04:44 PM
Quick Reply: Vibration/Shaking fairing
