Noise when leaning to left....'10 Limited
Hey folks, maybe someone can give me some ideas on this one. When leaning to the left on my '10 Limited, I hear a noise which I think is tire noise. When I straighten up, it goes away and does not do it when leaning to the right. I have heard what a bad wheel bearing sounds like on a Street Glide, but this does not sound like that. I'm thinking possible tire noise??? It has 12,700 miles on it...original tires. Thanks for any input.
-Jr.
-Jr.
My 2011 Road Glide Ultra when running at speed once you lean her over for a turn and not fully upright you have a growl from the tires.. now when moving slow,, under 10 mph and turn right I have a sound that is like bearings going,,,it just started a few days ago so when it goes in for its 15k check on Friday that is on my list to get checked out.
-Jr.
-Jr.
My 09 Road King, 14,000 miles, recently had a catastrophic front wheel bearing failure WITHOUT ANY WARNING! These wheels with the 25MM bearings in them have me spooked. If you're gonna start replacing tires I would advise to possibly change bearings at the same time. When I inspected the old bearings after removal, of the remaining 3 "good" bearings only 1 had a small amount of grease left in it. The other two were completely dry and probably headed for their own failures. This is a common problem!
