Need Help with RK turn signal bar w/plate LED
I have a 2010 Road King Police which came with the black radio box rack,. The license plate lamp is in the top of the tail light lens and the plate is mounted to the rack. I am replacing this today with 4-point docking hardware and relocating the plate below the tail light. I purchased used a HD turn signal light bar that has an LED license plate lamp in the middle.
I have everything figured out except - where does the connector for the LED plate lamp plug in to? There are no available spot inside the tail light assembly. See the pics below. Where does the middle connector plug in?
If you have a fender tip light, marry the wires to those- or splice in ( I was able to marry into my connectors)
if you don't have a fender tip light, you can use those pins- there are 3; blk is ground, blue is run, red is brake
you want power from a run light circuit
get someone to hold the signal bar level for you when you tighten the bolts
Mike
Mike
Looks like you have the Kuryakyn LED turn signals. Are you using the brake light too?
If so, there is a connector attached to the tail lamp that, IIRC, has a blue, red and black wires. Cut the connector off. Two of those wires are constant 12v. Cant remember the two, but you can use that to power the license plate lamp.
I can get either the Custom Dynamics fender tip brake/tail light to work OR the LED license plate lamp. So I'll figure out what is the best way to splice these and get it straightened out another day. It sure would be convenient if somebody made a plug and play pigtail for this.
Thanks!
UltraZac
05-29-2017 05:53 PM
UltraKla$$ic
04-25-2008 10:41 PM
