Outer primary cover won't pry off.....
Old 08-24-2013 | 11:26 AM
jacknthebox's Avatar
jacknthebox
Default Outer primary cover won't pry off.....
I've gotta a knock at idle and heave read that it could be a loose compensator nut on my 2000 RKC w/57K.
I've got both inspection covers off and all screws on the case are out but the cover will not budge.
Any tips? Is this normal?
Old 08-24-2013 | 12:01 PM
Jinks's Avatar
Jinks
Yep. Normal. Use a rag to protect the cover & a soft rubber mallet. Put the rag on the cover & hit it with the mallet. Several sharp, but not real hard, blows from different angles will break the adhesion. Be prepared to catch the cover if it falls off.
Old 08-24-2013 | 12:02 PM
jacknthebox
Thanks Jinks - I will proceed.
Old 08-24-2013 | 02:32 PM
oricko's Avatar
oricko
cloth and soft hammer an hard hit, also someone to catch it or protection for when it falls.
Old 08-24-2013 | 02:42 PM
senna's Avatar
senna
Leave a couple bolt in but backed off a full turn or so, then it wont fall.
Old 08-24-2013 | 03:50 PM
jacknthebox
thanks guys - the rubber mallet did the trick - had my daughter catch it.
Old 08-24-2013 | 03:57 PM
2's Avatar
Sorry to hear you hit your daughter in the face with the mallet
Old 08-24-2013 | 05:19 PM
TUCCI's Avatar
TUCCI
I just grabbed it by the inspection derby hole and pulled outward and off it came.
Fatboy5567
10-31-2017 06:50 PM
Joe What
05-23-2012 05:34 PM
HTNHARD
03-08-2012 05:40 AM
jtbredneck351
Ironhead
07-01-2009 08:42 AM
kelton3
05-01-2008 03:36 PM
Quick Reply: Outer primary cover won't pry off.....
