Switching wheels on my Limited to Streetglide Wheels...Bearing question
Old 08-22-2013 | 08:31 PM
Talldog's Avatar
Talldog
Default Switching wheels on my Limited to Streetglide Wheels...Bearing question
I just scored brand new Wheels and Tires from a 2013 Streetglide that I'm gonna be putting on my 2012 Limited.
Both front and rear wheels from the SG currently have non-ABS bearings installed in them on both sides. (9276A)
My Limited has ABS.
Looking at my parts catalog, it looks like just one side of the wheel uses the ABS bearings, and the other side uses the non-ABS bearings.
I'm gonna be replacing the wheels on the bike myself, but I don't have the bearing tools, so I'm gonna bring the wheels to my dealer and have them switch the bearings to ABS bearings.
If my thinking is correct, all I need to buy is (2) ABS bearings (9252) correct? I'll be leaving my current ABS bearings with my Limited wheels.
Sound right, or is there something I'm missing?
Thanks
Old 08-22-2013 | 08:37 PM
Gunnysgt's Avatar
Gunnysgt
Sounds right, they have a special tool for pulling the old bearings out, puttin the new one in is the easy part. I take a piece of threaded rod and large washers with a nut to ease the new ones in place.
Old 08-22-2013 | 08:45 PM
Lowcountry Joe's Avatar
Lowcountry Joe
There might be a different inner spacer length you will need when switching from nonABS to ABS. Remember that ABS bearing is about 3 mm wider than nonABS bearings.
It's possible that the HD dealer shops installation protocol will require that the nonABS bearings be pulled from both wheels and replaced with new. Why? Because the service manual procedure has you installing the ABS side first, then insert the inner spacer, then install the nonABS side until it just touches the inner spacer.
I doubt they will reinstall the "pulled" nonABS bearings. Liability issues. So it's a safe bet that you will need to buy the two ABS bearings plus two new nonABS bearings....and maybe an inner spacer for each wheel.
Old 08-22-2013 | 09:05 PM
Talldog's Avatar
Talldog
Joe, according to the parts book, the same "inner bearing spacer" is used on all wheels ABS or not. But, I see your point about the dealer having to do it in a certain order and them not wanting to re-install the bearings.
Guess I'll just have to wait and see what they say.
Thanks!!
Old 08-23-2013 | 08:31 AM
EasTexUltra12's Avatar
EasTexUltra12
I just asked the same thing a few days before. I too am swapping wheels on my 12UC. You might find that thread interesting.
https://www.hdforums.com/forum/touri...-about-it.html
David
Old 08-23-2013 | 09:21 AM
lp's Avatar
lp
It's the same spacer. You just need ABS bearings.
Also, you can find a complete bearing removal/install kit on ebay for 100 bucks.
Paid for itself the first time I used it. In the drawer it sets for next time.
lp
Old 08-23-2013 | 09:59 AM
Lonewolf176's Avatar
Lonewolf176
You need to replace both bearings. The abs bearing has to be installed first and the other bearing pulled to it.
Old 08-23-2013 | 10:46 AM
Talldog's Avatar
Talldog
David
lp
Thanks guys!
Old 08-23-2013 | 10:56 AM
0ldhippie's Avatar
0ldhippie
What ya gonna do with your limited wheels??
Old 08-23-2013 | 11:12 AM
Talldog's Avatar
Talldog
Hippie, they'll be for sale with the tires and ABS bearings and front rotors.
Haven't taken them off the bike yet, should be great condition, but I haven't had the chance to really inspect them.
Bike is a 2012 Limited with about 11500 miles.
After I get them off and cleaned up, I'll list them for sale.
If you're interested, send me a PM and I'll let you know details after I get them off.
Thanks
Quick Reply: Switching wheels on my Limited to Streetglide Wheels...Bearing question
