Templae for Tour Pak Rack ?
Old 03-05-2007, 01:32 AM
Badbagger's Avatar
Badbagger
Badbagger is offline
Default Templae for Tour Pak Rack ?
Hopefully yall can help. I've got a Premium Tour Pak Rack that I'll be installing and don't have a template for it nor have I had any luck in finding one. Anyone have one lying around or know where I can pick one up? Rack is part #P/N 53665-87.
Thanks
Old 03-05-2007, 02:12 AM
TexasRedneck's Avatar
TexasRedneck
TexasRedneck is offline
Default RE: Templae for Tour Pak Rack ?
Shoot me yer snail mail addy an' ah'll git ya one over...Just so happens ah have an extry one here!
Old 03-05-2007, 03:33 AM
FLGEEZ's Avatar
FLGEEZ
FLGEEZ is offline
Take a look at the info from an earlier thread. There are some good install tips here.
https://www.hdforums.com/m_1248844/tm.htm
Old 03-05-2007, 08:45 AM
Badbagger's Avatar
Badbagger
Sent cha an email.
Thanks!!!!!!!!!!!!!!!!!!!!!!
BM
Old 03-05-2007, 08:48 AM
Badbagger's Avatar
Badbagger
Thanks for the link. Good info and much appreciated.
Old 03-05-2007, 11:08 AM
berettag's Avatar
berettag
berettag is offline
I see you're getting the info sent to you. Did mine last year, was a piece of cake. Remember, measure twice. I highly recommend doing the pilot holes to keep the drill bit on track.
Old 03-05-2007, 11:16 AM
billnourse's Avatar
billnourse
billnourse is offline
I think I have one laying around but it looks like TexasRedneck has you covered. If something happens let me know and I'll see if I can find the one I have.
Regards,
Bill
Old 03-05-2007, 01:15 PM
Silverearl's Avatar
Silverearl
Silverearl is offline
Mine came with the template but found it was to big for my tour trunk so I just did a lot of taping and measuring before I drilled.. Looks great and perfect fit. Need more help let me know.. Glad to assist if I can.
Old 03-05-2007, 09:51 PM
choochoo's Avatar
choochoo
choochoo is offline
personally here is what I did
1 inch wide masking tape. or wider
set tour pack rack on the lid.
squared it up.
put one piece of tape under each leg.
made sure was still sitting square.
Used fine tip marker, drew ring around leg on the tape.
Drilled hole in center of ring, one size (1/16/")larger than bolt.
Removed tape. applied small dab clear silicone to lid and the
top side of the black trim rings.
bolted it on.
Silicone helps prevent water weeping.
Tape helps prevent paint chipping when drilling.
Use a variable speed drill and drill slowly.
Old 03-05-2007, 09:58 PM
FLHT's Avatar
FLHT
FLHT is offline
boogyman...........see my tip from the thread mentioned above this works great because you can actually see how the rack is going to set on the tour pack and spacing between the front of the rack can be adjusted so to make sure it doesnt rub your back rest before you drill them holes. No going back after that happens.
Quick Reply: Templae for Tour Pak Rack ?
