2014 bluetooth headset
anybody know if the new 2014 limited will come with one Bluetooth headset to link up to that six and a half inch touch screen. and what brand and model of Bluetooth headset that will be. IMC? Like the hardwired headsets of years past. Is there still a comm port to plug in a hard wired headset on the dash on the 2014 bikes?
OK, if you want bluetooth (sorry, listen mode only for CB), then you'll need a Sena SM10, Sena SC-A0120 and a SMH10. What this will do is the SM10 will plug into the hardwired port on the Ultra using the SC-A0120 and then the SM10 will pair with the SMH10. The good news is that the SM10 will pair with two SMH10. You'll get all the audio that comes out of the hardwired jack, be able to use the touch screen and or handlebar controls to switch between audio, GPS, etc. The only problem is the voice for the CB want go back over the SM10, it's one way only. Too bad, but I'm not on the CB that much. I've got a wired cord for that if I every need it or until someone makes a bluetooth unit that will work with the CB. I tried pairing the SMH10 directly to the Ultra (I have a 2014) and although it saw the device, it would never pair. Searching the net found no one who was successful and a lot of folks who talked to their Dealers who said you couldn't do it.
Hope this helps someone.
