2013 Engine run cooler after exhaust and tune?
Its seems on a 80 degree plus day I can't get stopped at more then 4 or 5 lights before "parade mode" kicks into full "**** me off" mode. Then you have listen to the ping for the next 20 plus miles on the highway. How much does a exhaust and tune solve this problem on the 103ci or do I need a bigger oil cooler on top of that? I'm thinking of flo-coating the exhaust also to cut down on temps.
I had a 2010 SG with a 96ci and that stock bike didn't run anywhere near as hot as the stock 2013. I got caught in bad traffic several times and never worried about my bike over heating or pinging. I worry about a trip across town on the 2013 and what the high oil temps are doing to my bearings!!
you can turn off the eitms
although that makes no sense to me, maybe that's something you need.."**** me off" ha.
the eitms is more than just "turn off the rear cylinder"- it also pumps air through that cylinder and that air is now removing alot of heat from the motor. the rear cylinder is used as it always runs hotter than the front- less fresh air flow to the rear
make sure you have a quality motor oil- the old dyno will not stand up to the heat. a quality oil will reduce frictional heat, and will carry heat away from the hottest parts of the motor ( heads and bearings) to be dissipated.
add a fan kit to your oil cooler
adding more gas to the air will cool temps, but within bounds.
an over rich mixture may corrupt the oil, and cause carbon deposits in the combustion chamber resulting in non-stop pinging.
an exhaust without a catalytic converter may allow heat to dissipate quicker
many of us ride in temps much, much warmer than 80º.
thick jeans are better heat protection than thin
Mike
Mike
Get rid of catalytic converter and richen AFR's a little. That should help solve the issue with traffic as much as can be expected. My experience so far, even in 95* Florida heat, is that when moving, the oil cooler is doing the job. My bone stock '13 is hotter than my '05 was, but not that bad. And I'm thinking once I get rid of the catalytic converter and add Xieds, it'll be as cool, or cooler than my '05 was without an oil cooler
Yes MK air cooled engines like 13.5 to 13.7:1 AFR for the best head cooling. My question is not how parade mode works (I already now that), its how to get the engine to run cooler and what people have seen with a exhaust swap and tune. The high oil temps that initiate the parade mode are unacceptable. Going down the road at speed is not the problem, stop and go traffic is even if it short lived.
So any one with real experience with this and what have you seen and has it lessened the frequency of the bike going into parade mode on the 103ci engines in stop and go traffic.
Mine does the same thing. I have a complete stage one setup. My bike is running at around 218 degrees in stop and go and yet my parade mode kicks in too. I don't think my bike is running hot. I can ride with other people with the same motor and they never go into parade mode. I wonder if there is a setting for when the parade mode kicks in and mine is set too low.
