Adjusting clutch
Old 08-17-2013 | 05:17 PM
cowboy-bc's Avatar
cowboy-bc
Default Adjusting clutch
My 07 FLHX has nearly 50 k and I was thinking I should do an internal adjustment? I have done it once on a friends bike but quickly how again?
thanks very much
Old 08-17-2013 | 05:22 PM
Txn09's Avatar
Txn09
take off derby cover, loosen jam nut on shaft, turn shaft with allen wrench until resistance is felt, then back off 1/2 turn and tighten jam nut back to torque spec
Old 08-17-2013 | 06:21 PM
TWIN CAM 96's Avatar
TWIN CAM 96
There is a bit more to it than that check you service manual
Old 08-17-2013 | 06:34 PM
Stiggy's Avatar
Stiggy
thanks very much
"50 k" as in 50,000 miles without a clutch adjustment?
Gotta' ask, How often do you check your tire pressures?
Old 08-17-2013 | 06:56 PM
Def Mute's Avatar
Def Mute
If it ain't broke...
The service manual has the best instructions, IMHO.
Old 08-17-2013 | 07:08 PM
DPete's Avatar
DPete
Big Kahuna HDF Member
C908
04-03-2017 06:41 PM
ebeattie
06-04-2013 01:55 PM
ghoticov
07-30-2012 09:34 AM
FACTION95
04-11-2011 10:00 PM
swat469
06-04-2009 07:34 AM
Quick Reply: Adjusting clutch
