will non abs wheels fit onto abs bike??
Why would you need to change bearings? The only difference I see between the ABS and non, is that the ABS has a sensor on the left side front, and right side rear that double as spacers while the non ABS just has a spacer the same thickness as the sensor instead of the sensor. What am I missing??
Bill
Bill
abs bearings and non-abs bearings ARE different, and need to be switched. they even look a tad different. don't know what the difference is , though.
maybe the bearing is where the abs gets its reading as to what the wheel is doing. seems logical.
BUT you can switch the wheels just fine after changing the bearings.
good luck
good luck
stime63
03-21-2019 08:56 AM
