Clutch Release cover gasket replacement
Replaced the gasket on the clutch release cover today. There aren't specific instruction in the service manual for replacing the gasket.
I just popped the cover off enough to get to the gasket and put the new one on. Should I have made sure anything was aligned or should it have been that simple. The reason I ask is I can't get all the free play out of the clutch cable doing the clutch cable adjustment now, I'm a bit more then 1/8" gap and pretty well down to the end of the screw.
Please read the link, starting with the second post. I think that's what happened here.
https://www.hdforums.com/forum/touri...ctuation+cover
Yeah, I readjusted the clutch after I put this back on which is when I noticed the cable freeplay problem.
BTW, I'm able to pull the clutch in and change gears (though going into 1st from neutral seems to be louder then it was. Haven't test rode it yet, is raining. Also, if I have to pull the cover again am I able to reuse the tranny oil? I out new in today when I did the gasket replace and no place around here to get the red line oil.
Thanks Stiggy!
Thanks Stiggy!
Wanted to follow up on this.
I let it sit overnight and went back out and tackled it again fresh. I took Dawg's advice and put it up on 2x6 and leaned it over and opened up the clutch release cover. Lost a little tranny fluid but not much to amount to anything.
The lever was in the up position so not sure if that was the issue or if taking it back off fixed or not but put it back together, readjusted the clutch and was able to get he free play out of the clutch cable. It still seems to take a bit more adjustment so maybe my cable is stretching a little but it was no where near the end of the cable adjustment as it was yesterday. Maybe it was because it was completely cool bike? It was cool yesterday but it had ran earlier when I was warming the oil.
How long does a clutch cable normally last?
Thanks for all the help guys.
jothom122
10-04-2010 10:42 AM
