Custom graduating straight pipe baffles w/ MGS & BCT (PICS)
***Pics in this post to illustrate***
Just completed a custom exhaust job that took a lot more time/effort than anticipated but was TOTALLY worth it! I think I took enough pics and recorded enough part #'s/info to make it much easier for anyone else who decides to follow in my footsteps.
I started off deciding I wanted TD's to cool down the right and for sound reasons. Only thing that had slowed me down was loosing power compared to my 2-1-2's. So after all the talk about MGS and b/c the front pipe stayed straight the whole length, I went for them. Honestly, I have no reason to believe these headers are any different from the original Rineharts/Bubs, except they don't have that bend in the middle of the front pipe.
I also wanted them loud and as deep as possible. I called BCT since I used them previously with great results and talked with one of their engineers named Jim. Think he might even own BCT but I'm not sure about that. Anyway, I told him I had Bub 7 slip-ons with their QQ's but always wished it was a little deeper. He said if I really wanted the best exhaust I could put a graduating straight pipe where the original baffle was and I was intrigued. So we talked. That is what he has done on his. I chewed on it and decided to go for it.
He said to buy a bunch of exhaust adapters and put them together. That it would work best if you slowly graduated the exhaust diameter. So off to NAPA I went and they let me go back and play with their exhaust so I could piece things together. Here are the p/n's I ended up with:
→41949
→41958
→41966
→41974
→41970
→41890
These were all "in-stock" pieces at my NAPA, except the last one, which is a 3"OD- 4"OD. That piece was special order but they just happened to have two in-stock for a canceled special order. Lucky me! So put them together, measured total length, measured how long the original baffle was, decided where to cut, how much to cut, and double checked everything. For me the lengths ended up being:
→3.5"@2" diameter
→5.5"@2.5" diameter
→6"@3" diameter
→5" @4" diameter
I had to take the two 41949's down to an exhaust shop and have them flared, b/c that is how the original baffles secure to the cans.
The biggest hurdle was the fact that my last piece ends in 4" OD and the cans are also 4" OD. Obviously this won't work. I'd have loved to buy 3 7/8's OD but it doesn't exist. Or 3 3/4 ID but that doesn't exist either. Soooo...I cut straight down the whole length of the 4" section 4 times like a plus sign, thinking I could use a 4" muffler clamp to squeeze it. Nope. Didn't squeeze so well and the clamp didn't do it evenly. So I did 4 more slits for a total of 8 and used hose clamps instead. I did 2 clamps on each one at the diameter I needed and took it down to the exhaust shop so they could weld. Then of course removed the hose clamps. Wish I owned a welder, but I don't.
Another hurdle involved thinking ahead on how I would ever remove a baffle (straight pipe) that was the same exact diameter as the cans. I installed 3/8 Grade 8 bolts through the 3" section as close to the end as I could. Used Red Loctite of course. I called Jim back to inquire if this would have any adverse effects and he said no. He said it would likely have no effect, but if any it would be a positive effect.
I finished it up by filling the empty space between the pipe and the cans with insulation to remove higher pitched sounds, and used some exhaust wrap here and there to make sure everything is tight and make sure no metal could vibrate against each other.
BCT QQ's are at the exit of the head pipes for back pressure.
The sound is amaaaaaaazing!!!
More pics in next post...
→41949
→41958
→41966
→41974
→41970
→41890
→3.5"@2" diameter
→5.5"@2.5" diameter
→6"@3" diameter
→5" @4" diameter
Did you see the pictures??? I am not referring to the headers at all, except to say that I installed MGS headers. Yes, the MGS headers are of a stepped design. When I refer to a graduating straight pipe I am talking about the sections of pipe I put together/created/fab'ed inside the cans (mufflers) to replace the baffle the MGS's came with. I call it straight pipe b/c it has no holes like a baffle does. I could have called it a stepped muffler insert using solid pipe?
Whoa Jeff, that looks like quite the project! Glad to hear you were able to get it all wrapped up too. Nicely done!
Did you have the MGS exhaust already installed, or is this the first you installed it? I'm curious what you think about the power losses/gains.
How loud is the exhaust now? Any chance you might be able to post up a short video clip?
I did not install the MGS ahead of time. I didn't want the down time or the extra install/dismantle time. Plus I had to have a can torn apart to work the project. Sorry I can't compare for people who have, or have heard, MGS exhaust.
I really noticed no difference in power except approaching 90. I feel the new exhaust might be petering out maybe 10 mph sooner. Which really is not where I thought I would notice a difference. If anything that is where I might've expected an improvement.
Volume? Scale of 1 to 10 and 10 being loudest. Straight pipe no baffle would be a 10. Thinking MGS regular/Rineharts to be about 5 or 6? These are probably an 8. Reeeeally deep though. The deepest loud is what I was going for and I nailed it.
