Power Commander Maps
Old 03-04-2007, 11:31 AM
HDFLHT's Avatar
HDFLHT
HDFLHT is offline
Default Power Commander Maps
Hey guys I have had little luck with the standard maps posted on the power commnder website. My configuration may be common and thought I'd ask if anyone has already conquered the decel pop issues that has my configuration, and is willing to share their map.
Next step is to take in to have a custom map.
2003- FLHT
Twin Cam 88
VH true duals
VH Ovals
Power Commander (with usb)
Stage 1 modification
Old 03-04-2007, 03:13 PM
huffhuff's Avatar
huffhuff
huffhuff is offline
Default RE: Power Commander Maps
contact jamie at fuelmoto. he custom made a MAP for me and i had gotten my PCIII elsewhere. works great and he charged 0.
Old 03-04-2007, 03:22 PM
StreetGlide2006's Avatar
StreetGlide2006
StreetGlide2006 is offline
For what it is worth..................I asked Jamie the same thing about decel popping. He suggested changing the following:
In the 0 throttle range column from 1750rpm to 5000rpm set at 15
Mine were all 0`s at the 0 throttle range. The popping is caused by lean condition and this richens it up a bit.
I have not tried it yet as the weather here is to COLD!
Ride Safe,
Mike
iclick's Avatar
iclick
iclick is offline
ORIGINAL: huffhuff
That's service beyond the call of duty.
Old 03-04-2007, 04:27 PM
JeffSG's Avatar
JeffSG
JeffSG is offline
Jamie had me change mine to 10. Helped a little but need to have it tuned. I think my next step is to get a SERT and ditch the PCIII.
Peace,
ORIGINAL: StreetGlide2006
Ride Safe,
Mike
Old 03-04-2007, 11:51 PM
sligarn5's Avatar
sligarn5
sligarn5 is offline
I had the same problem with the canned maps from the disc I got with my PCIII. I finally just bit the bullet and put the bike on a Dyno Tuner at a stealership here in KC. The guy did a pretty good job for about $150.00. He increased my hp by a factor of 9 and the torque went up quite a bit as well (I don't have the graph in front of me so I can't remember by how much). All that as well as evening the fuel mixture very well, and I still get decel pop...although it's not nearly as noticeable as it was before. My advice: find a Dyno and operator that you like and spend the cash. It's worth it.
Old 03-04-2007, 11:57 PM
Taterdog's Avatar
Taterdog
Taterdog is offline
ORIGINAL: sligarn5
Hey, sligarn5, I live in Lenexa. Who did you use locally for your dyno?
Old 03-05-2007, 09:28 PM
sligarn5's Avatar
sligarn5
sligarn5 is offline
Taterdog...
I just happened to call Blue Springs Harley and ask about it. I honestly thought that I would have spent less going to the Kawasaki dealer off of Santa Fe (and I am not sure that it is not cheaper) but when he quoted the price, I said I'd be right down. It took him about 45 minutes to do it and he went through, maybe, seven runs to get it right. I was happy with it. I don't remember the guy's name, but he was the service manager.
Old 03-05-2007, 09:36 PM
FLHT's Avatar
FLHT
FLHT is offline
Have it Dynoed
Old 03-05-2007, 11:47 PM
Taterdog's Avatar
Taterdog
Taterdog is offline
Sligarn5,
Do you know if Central HD offers dyno tuning for Power Commanders? If not, Blue Springs is just a ride away, especially if he can do it while I wait.
Thanks,
TD
Quick Reply: Power Commander Maps
