Khrome Werks 300504 handle bar ?
Been looking at old threads and not finding an answer.
So maybe some with the older RK's that have used these bars can help me out.
I have an 05 RK and am thinking about the KW's 300504 +2" taller wide sweeper bars.
Will I need to go with longer cables with these bars or does the stock length work?
They [web sight] say the +2 FLHT does take longer cables but I'm not sure for my bike.
Thanks
Thanks
I know. I've been looking at different bars for the last 2 weeks and I think I've got it narrowed down to the KW's.
What I have found is one shop will have one bar another shop may have a different bar or they'll have no bars I'm looking for. And I don't want to order bars with out a dry fit to see how they will feel. I'm only about forty mile from J&P's, so I can test fit the KW bars.
But I not sure on the cable length on this model.
I also have the +2 sweepers and I did not need to change out the cables. I had the dealer install the bars before I picked the bike up and they installed a longer ss clutch cable which I thourgt look bad with the brake line being stock black so I installed the OEM clutch cable back on and it fit great.
With the Road King cable routing is a lot easer.
Thanks
Thanks
I had to loosen the hydraulic clutch banjo and front brake banjo and rotate them a bit then tightened them back up. Didn't even have to bleed anything...
