Can't see what I just spent $$$ on
Old 08-12-2013 | 04:09 PM
SBates08's Avatar
SBates08
Originally Posted by FXDWG12
Depends on what tire you run with that combo. And if you don't mind running on a rubber band for the front. Cause you'll be loosing 1.5" of sidewall to maintain that height.
Same tire and wheel combo as what came on the '12 SG. Looks better and handles better than the slugs that comes factory on the Ultras. And no difference in ride height either.
Old 08-12-2013 | 08:08 PM
FXDWG12's Avatar
FXDWG12
Looks to me like the 12 SG has a 130/70-18. And the overall height is about 25". This leaves a sidewall height of about 3.5". And the 08 SG has a 180/65-16 with about 25.5" overall height. Change the wheel to 19" and reduce the sidewall height to 3". So maybe something like a 120/65-19?
Old 08-12-2013 | 08:30 PM
DuraGlide's Avatar
DuraGlide
130/60- 19 stock tire for the CVO bikes. Mine rides just fine.
Old 08-12-2013 | 11:12 PM
SBates08's Avatar
SBates08
'12 CVO SG was what I meant. Anyhow none if this actually helps the OP. What would've helped him more would've been a knowledgeable person behind the parts counter at the stealership. Finding this more and more where the guy behind the counter knows less about your bike than your OL. If it were me I'd take it back because I wasn't satisfied with the look. Dealer may balk on you but it's worth a shot.
Old 08-12-2013 | 11:21 PM
Mike's Avatar
Mike
Originally Posted by baron515
Excellant Point Dennis,
Thanks for pointing that out! I guess I didn't think about that. When you see a pix of a new wheel you get that picture in your head. Hell, it didn't even click with me when I ordered the rotor's that I wouldn't see alot. So I guess the best thing to do to salvage this is remove the brake compo from atleat one side.
Most of us who have gone to a single side front brake on the touring bikes have also swapped out for a six piston brake caliper (PM, Jay Brake, HHI, etc)
Old 08-13-2013 | 01:45 AM
White Ice's Avatar
White Ice
Originally Posted by Hogpro
You will not lose 50% of your braking power but if you want the wheel to look right you will need a hub with a smooth cap on teh right hand side, otherwise you will have the holes for the rotor showing.
We do many single disc conversion and in most cases you keep about 80% if your front brakes stopping power.
What if you take the wrong side off? Have you lost 80% of your stopping power? Which side is the 80% and which side is the 20% ?
Old 08-13-2013 | 05:56 AM
Jswerve's Avatar
Jswerve
I just purchased a new wheel from RC Components for my 08 Streetglide and stayed with the stock 16" instead of going bigger because I was already having trouble not being able to be flat-footed at a stop light. Problem is I can't see it due to the dual rotors on both sides. How will removing the the rotor and brake off one side affect the overall front end braking?
I did this on my old bike (09 FLHX) I will will never do it again UNLESS I go 6 piston caliper and 13" rotor. You lose a lot of braking power and I regretted it from day 1.
Old 08-13-2013 | 06:12 AM
Shakeydeal's Avatar
Shakeydeal
Mike is right. Go with a six piston caliper and 13" floating rotor and you will retain most of your braking power, and it looks so much better.
But as usual. Better = Mo $$$........
Shakey
Old 08-13-2013 | 06:55 AM
acchd's Avatar
acchd
When read title thought your going to say rear wheel
Old 08-13-2013 | 06:57 AM
BoonDock_Saint's Avatar
BoonDock_Saint
I wouldn't give up 1% of my front braking so I could see a shiny wheel. Collision avoidance is alot higher on my list of priorities. I don't know this but maybe if you went to a large brembo caliper and rotor you wouldn't lose anything and still get the result you want.
Quick Reply: Can't see what I just spent $$$ on
