Saddlebag locks.
I just realized that one of my locks on my 08 Street Glide has come apart on my and I can no longer lock that saddlebag. Before I go and order a new set of locks I though I'd throw it out there to see if anyone on the board has some take off parts. Hoping not to have to drop 50$ and carry another key. I am only missing the part tab that pivots to actually do the locking and a nut to secure it.
Thanks
Brian
Thanks
Brian
I just repaired both of mine today. Halfway through a 500 mile on Saturday I opened the right saddle bag. The nut, spring, and locking tab fell onto the ground. They don't fall into the bag as they're mounted on the outside. I just closed up the bag but couldn't lock it. Today I removed the nylon strap off the lid and put the lock back together. I checked the other side and it was 1 thread away from falling off.
To the OP, look here:
http://partsfinder.onlinemicrofiche.....asp?make=hdmc
Search for saddlebag assembly in the OEM parts finder.
Same thing happened to me. The nut and lever fell on to the garage floor. I checked the other bag and all was well there. In stead of ordering the $100 part I decided to make my own. Just found some similar metal. Removed the lever from my other bag and traced it out. A few minutes later I had a new piece an the bag locks again. Simple fix.... Zero Harley bucks.
![Icon Worthless](https://www.hdforums.com/forum/images/smilies/icon_worthless.gif)
friend of mine got some latch's and locks off e-bay and I won't say they are junk but you do get what you pay for , ok they are junk , at least the ones he bought
I suggest taking both locks off and going to a locksmith. I bet he can dig into a drawer full of used parts and come out with a locking tab and screw in less than 5 minutes. Probably will not even charge you. If so, It would be worth $5 or $10 just to have that piece of mind. Good luck
![Icon Patriot](https://www.hdforums.com/forum/images/smilies/icon_patriot.gif)
