A Pushrod Question
Old 08-10-2013, 12:27 PM
Girthstick's Avatar
Girthstick
Girthstick is offline
Stage II
Default A Pushrod Question
My (new to me) 96 Electra Glide has really terrible valve/pushrod/rocker arm clatter and upon checking out the pushrods I found that they're the original equipment rod with no adjustment.
At 52,000 mile I guess I shouldn't be suprised..LOL...Makes a lot of what sounds like "rattling" when I back of the gas. If you've had it you know how it can just bug the hell out you, especially with the fairing pushing all engine noise up to you (Which is good and bad).
My question is I know I can remove the old pushrods with out removing the tappet covers if I cut them out and install the new adjustables but should I also put in new lifters at the same time?
Also would it make more sense to buy new gaskets and remove the covers to inspect the rocker arms? Just trying to get a feel for what I may be getting into.
On the plus side, it runs great now with all kinds of pull (I thing in part to rebuilding the Mikuni carb). I'm in Michigan so when the snow flies I'm going to undertake this project along with my front left fork seal is leaking oil and won't hold air anymore so I need to rebuild both sides of those.
Thanks of any input..You guys have a lot of good experienced knowledge.
Old 08-10-2013, 12:36 PM
Fast Aire's Avatar
Fast Aire
Fast Aire is offline
Former Sponsor
With the EVO motors it was common to put in adjustable p-rods to reduce the valve train noise. Seeing that the lifter rollers are mated to the camshaft, I wouldnt put in new lifters unless I changed the cam.
But as it often happens, replacing one part of the motor can lead to a complete top end rebuild...bigger pistons, head work, camshaft, etc. I know its happened to me !
Old 08-10-2013, 12:39 PM
$tonecold's Avatar
$tonecold
$tonecold is online now
Received 1,854 Likes on 1,001 Posts
When you say 96 do you mean year model or engine size. If it is a 96 year model it would be the EVO engine which has some different metrics than the Twin Cam. It has been a long time since I worked on an EVO so I would have to do some research in order to give you an answer.
Old 08-10-2013, 12:59 PM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,867 Likes on 2,429 Posts
Welcome to HDF from the UK. While you're investigating this, pop over to the Evo section, if your bike is a 1996, where you will find plenty of other Evo owners, who talk the language you need to hear!
Old 08-10-2013, 04:35 PM
nhrider1's Avatar
nhrider1
nhrider1 is offline
If you got 52,000 miles out of the original lifters you are very lucky. Evos were known to have issues with lifters and cam bearings.
If I were you I would consider replacing the entire set of lifters with good aftermarket replacements. If you are already considering adjustable pushrods, it will make the job easy.
Old 12-05-2021, 06:05 PM
drifterawh's Avatar
drifterawh
drifterawh is offline
4th Gear
Lifters is the problem to begin with..
Old 12-05-2021, 06:59 PM
Keithhu's Avatar
Keithhu
Keithhu is offline
Received 5,609 Likes on 2,727 Posts
Well 8 years on I'm guessing he figured it out.
Old 12-06-2021, 09:14 PM
OLD 96's Avatar
OLD 96
OLD 96 is offline
Received 2,389 Likes on 959 Posts
WTF.??? Ya'll mother fers got me looking at a 8 year old thread. And we still don't know what happened to Girthstick. WTF kind of handle is that?
Old 12-06-2021, 09:17 PM
Taxgod4u's Avatar
Taxgod4u
Taxgod4u is offline
Received 1,320 Likes on 602 Posts
Better than Chode!
mikeyhd
Shovelhead
09-25-2017 07:22 PM
riderboy1961
Exhaust System Topics
12-14-2013 01:38 AM
rziraschi
04-22-2013 10:33 AM
LowPerformance
07-25-2010 04:40 PM
mike90715
06-15-2007 07:05 PM
Quick Reply: A Pushrod Question
