What is a good price for Harley Race Tuner?
Better yet, the TTS Mastertune, the upgraded successor to the SERT and developed by Steve Cole the developer of the SERT.
http://mastertune.net/harleydavidson.htm
You can find them on E Bay for about 350-375 , be sure it new in box never used they are only good for 1 ECM since they marry to the ECM. Then you also need cables if your using it your self.
Id check into any of the other Falsh Tuners out there. TTS Power Vision ect. I like Power Vision because of ease of use , data logging and the customer support from Fuel Moto can not be beat. If you chose PV buy if from Fuel Moto
You can get a second or new license for the PV for $199. If your tuner can use the SEPST he can use the PV. The tables are all the same and use the same strategy format. Yours is either a 9 or 44 strategy. If he isn't going to dyno tune just get the new license from Fuel Moto as I hear they can do the new license now. They will also send you a map that will work with your tune. If for some reason you can't get a map from FM, I can send you one that will work. Just send me a pm with your email address and I can send you a map. Need the parts after market performance parts on you bike. Cams, exhaust and intake, and heads and compression if not stock.
TOMMYBLAZIN
18
09-08-2017 10:58 AM
