B. Woods Roller Chain Conversion kit
I guess it would depend on whether you are planning to change your cams or not. The Harley 25284-11 allows the use of the early model cams, but upgrades the cam chain tensioners to hydraulic. The Wood kit requires that you buy a conversion cam in order to use it. If you go with the SE 25282-11 you would also have buy the conversion cam, cam chains, sprockets, and tensioners. The advantage is a slightly better oil pump, billet cam plate, and you could get the Zipper's dual piston tensioners, which in my opinion are much better than the stock items.
Iron lHorse
11-10-2013 07:38 AM
kiwideuce
11-19-2011 08:12 AM
