Question about PIAA replacement bulbs for front lights
Question about lamp replacement. I use the PIAA 70456 Xtreme White Plus H4 as a replacement for the stock HD bulb on the headlamp, and was wondering if anybody knew the PIAA replacement bulbs to go into the two spot lamps? I'd like to get the light colors the same across the three lamps.
Thanks!
Thanks!
My stock bulb was an 881 long life 27w. Other bulbs that will fit are the 898 35w and an H11 base but I suspect the standard H11's at 55w are too hot. There are starting to see some H11 led's on the market in higher light output(50-60 watt light output) but have not seen them in wide supply yet or proven life. Do a Google search for H11 Cree 60w led and lots of foriegn sites pop up. Cree is usually a quality led supplier used widely in commercial applications but the manufacturing quality of these bulbs needs to be proven. I'm also running the PIAA H4 and have changed to the 898 spots and the color does not match but I like the increased light.
Same here. Been a bear trying to find the correct replacement bulbs for the spots to match the PIAA; I figured somebody here must have the found the right solution already.
