Oil Temp Gauge Reading 110F
Just replaced the ambient air temp gauge with an oil temp gauge. I ran the bike for about 5 minutes while up on the stand and the gauge went to 110 and stopped. Is this normal since it's not being ridden or put under load? I know plenty of you all have done this modification based on threads I've read--so I'm hoping this is just a matter of running the bike under load to get an accurate temp?
Ditto. It takes a good bit of riding in heat to make that gauge move. Oil does not transfer heat well and it takes the oil a good bit of travel through the engine before it gets that hot and then up against the sender.
I have a Baker +1 pan and I had to put the sender in the drain hole (the plug hole was too close to another piece for the tall sender to fit) and unless its pretty warm, it takes a while to move. And if its below 70, you can almost forget about it.
Still think its a great advantage over the air temp sender. If the engine gets hot enough to move that dial, it will work when you NEED it to.
Just the standard HD Oil Temp gauge kit. Put the sender in the oil pan where the allen head plug is. You may need a brass adapter.
Here's a link to a dealer, but only because I was having trouble getting the link from the HD site.
http://www.latus-harley-davidson.com...ng-Mount-2.htm
Hellbob37, here is a link to the site where I purchased this. They were lower on the cost than most and didn't charge shipping ($116 total). It arrived two days after I placed the order online.
http://www.kutterharleyonline.com/harley/70900284
