Autotune installed
Autotune installed
got my new O2 bungs welded in and autotune installed friday. rode about 300 miles over the weekend. autotune made my bike run much smoother and most of the decel popping is gone but not completely.
couple questions i have are what should the paramiters be set at on the autotune such as min temp and what ever else that is on the screen when you configure it. i dont have it in front of me right now so dont remember it all. i think i read in an old post somewhere that it will only adjust the 20% and then you need to go in and reset it after a little while. is that correct?
Received 75,536 Likes
I used the default temp setting and would apply trims after every ride. If you get a map that is close to start with, you shouldn't see many trims that are above +-20 percent. I ran a map until I would see adjustments of no more than 3 percent then I changed the map to adjust based on gear and changed the target AFR in the cruise range to 14.5 for gears 4-6 and ran several more time until barely any adjustments were made. All in all, it took about a thousand miles before I felt I had a tune for all conditions. I set this as my final map and unplugged the auto-tune and removed the O2 sensors. I have done this on two bikes and have run at different elevations and temp conditions without any issues. Fuel mileage is around 41MPG during a group rides and a little less if I get on it. I'm actually going to do this same process on my wife's Sportster next spring.
sorry i was still half asleep lol i ahve the power commandor set up. another question i ahve is what the lights on the autotune actually mean? when i start bike i get 3 red flashes, pause, 3 red flashes, solid red light after all that. the other light has not came on at all. i searched and found nothing on theirir function. i did see once i get solid red light my laptop reconized the autotuner.
Straight from the DynoJet helpdesk...not like I had the same question when I installed mine or anything...
The 3 red flashes are the AT module self-testing its' O2 sensors. It'll do this a few times, before hopefully settling on to a solid red light. That means all is well.
Puttnutt24
07-27-2007 07:31 PM
Ace07FXDL
07-20-2007 01:57 PM
