Checking belt tension
I have seen threads where people twist the belt 45 degrees each way to check tighness. I myself will invest in the correct tool for the job. My bike is worth way to much to be guessing on stuff like that and I dont wanna be "that guy" whose belt breaks because it is to loose or tight in the middle of bum f_ck Egypt, lol..
Well what I did was to get my kitchen scales out press on the scale pan until I deflected it to 4.5kg, just to see how much effort it took, then remembering that amount of effort, and how tense my hand was i checked the belt tension and measured the deflection with a ruler. Sounds insane, but like the above post says once you get a feel for it you don't need the gauge. I bet 9 out of 10 dealers don't even have one, let alone use it.
The reason I checked mine was because I was getting a nasty vibration through the footboards at one point on decel. I'd just had new tires fitted they had over tensioned the belt when re fitting the back wheel.
When my 2010 Limited was brand new, I discovered that the belt would have the proper tension when the bike was cold, but after a couple of hours of riding in ninety degree temperatures the belt would be banjo string tight. With all I read about the primary and transmission bearing failures, I readjusted for proper belt tension when she's hot. When she's cold now the belt is a little loose, I just ride her easy till she warms up, the belt tension seems right. Knock on wood, so far no striped belt teeth, also no bearing failures. With my Evo powered Heritage, and my TC88 Roadking's wider belts I never had this BS over the belt tension.
So has anyone else experienced these new skinny belts tightening up when it's hot?
Just set my belt tension on a 2012 FLHX using the gauge. Manual says to do it cold, and check at several different spots and select the loosest spot. Glad I checked several spots because there is a fair amount of difference between the tightest and loosest spot around the whole belt. And I gotta say, the "45* of twist" thing can't be correct. I'm pretty weak but when that belt is set as per above I don't see any way that you are gonna twist it 45* unless you are pretty fu@%in' strong.
