1k critical fasteners
So what do u guys think are the most critical fasteners to be checked and torqued out of all the critical fasteners. To me. I beleive it is engine and triple clamp bolts. In racing, the triple clamp bolts can be torqued at different specs to make the bike handle different.
the 1K check is more double checking the work of the dealer set up tech...who could be awesome or crap...
I consider all fasteners critical.
read about Guys saddlebag lids falling off etc.. ( my set up was great with thread locker on these)
so basically sit down with a cooler and take the time to go all over the bike double checking fasteners, routing of wiring and any seeps/leaks etc.
there is a well described "fall away" test for the neck bearings- the HD touring triple tree is "backwards" to other brands.
the test spec vary per model, and some require the clutch cable or wiring to be disconnected
mike
mike
Critical Fastners are as follows:
Hand Controls--------------------------------
switch housing screws
Clutch lever Bracket handlebar clamp screws
Master cylinder reservoir handle bar clamp screws.
Brakes--------------------------------------------
Brake caliper banjo bolts
Master cylinder banjo bolts
ABS module banjo bolts= if equipped
front brake disk screws
rear brake disk screws
front master cylinder reservoir cover screws
rear master reservoir cover screws
rear master cylinder to frame screws
front brake caliper mounting screws
rear brake caliper mounting screws
Axle Nuts---------------------------------------------
front
rear
Front forks------------------------------------------
Front axle holder nuts
Fasteners
rear fork bracket bolts
transmission to engine bolts
engine mount bolts
top stabilizer link bolts
rear frame bolts
front
rear
Fasteners
engine mount bolts
rear frame bolts
Guess I'll be doing my own "critical fastener" checks from now on...
