NEED HELP! brake light on all times
I have a 07 road king. the rear tire (18") has rubbed thru the harness and shorted it out. it blew the fuses. I replaced the fuses, repaired the harness but now the brake light stays on all the time. If I pull the relay it goes out. If I pull a wire off the rear switch, nothing changes. I have the manual but the wiring diagram is not very clear on this matter. Any help would be awesome
Ditto. Front brake light switch broke on mine causing that reaction with the brake light. Check both switches.
Install a spacer in the brake lever then pull the front brake lever off. CAREFULLY depress the rubber boot for the break light. If the light goes out, it's broken. I broke mine. Ordered another on ebay and it's the same. There is a little, tiny, itsy, bitsy tip that breaks if you look at it wrong so be carefull. I figured the new one would break so I put a dab of Black RTV on the break lever so it pushes the switch in. Been working for 5K now.
FLHPRK
FLHPRK
