Is the Tour Pak position adjustable?
Old 07-23-2013 | 10:47 AM
Crimson's Avatar
Crimson
Default Is the Tour Pak position adjustable?
I read somewhere that the Tour Pak on the newer models is adjustable? It can move backward up to 1.5 inches? Did I read that correctly or is some type of kit required to do that? If it is possible are there any instructions out there on how to do it? 2013 Ultra Limited FLHTK.
Old 07-23-2013 | 10:59 AM
mkguitar's Avatar
mkguitar
the T/P has 2 positions std. on set up the dealer is "supposed" to mount in the rearward position. check that first- maybe they didn't
if you need more room, there are all kings of spendy kits - or forum member DAWG has published a DIY mod, $5 and a drill.
-search for it
Mike
Old 07-23-2013 | 11:04 AM
CSMHOG's Avatar
CSMHOG
You can move the tour pak up or back by about an inch. Not being able to tell which position yours is in currently makes it difficult to say which way you can move. If you take out your liner, you can see what options are available to you.
Old 07-23-2013 | 12:28 PM
JoeRock's Avatar
JoeRock
How does the liner come out, is it glued in? After quick peak (13' FLHTK), it doesn't seem to be bolted down, looks like the 12V plug may be the most difficult to get liner around. Anyone take their liner out recently?
Old 07-23-2013 | 12:38 PM
stro1965's Avatar
stro1965
It just pulls out after you remove the document holder pouch. Helps to collapse the sides a little.
Old 07-23-2013 | 12:43 PM
CSMHOG's Avatar
CSMHOG
Spot on here ... I take mine out all the time. You just have to wiggle it out from around the charger outlet.
Old 07-23-2013 | 01:20 PM
JoeRock's Avatar
JoeRock
Good info! I plan to pull my liner this weekend to install premium tour-pak hinges. I'll take a close look at the tour-pak position at that time. Thanks...
Old 07-23-2013 | 01:36 PM
stro1965's Avatar
stro1965
FYI, you can tell what position it's in by looking at the underside of the tourpak. No need to pull the liner to check it.
Old 07-23-2013 | 01:48 PM
mkguitar's Avatar
mkguitar
exactly, you'll see the molded in ridges that position the tourpak on the mount.
* before doing the hinges, read up on some of the posts for tips.
that'll make it easier.
mike
Old 07-23-2013 | 08:39 PM
Crimson's Avatar
Crimson
Thanks for the help everyone I'll take a look.
Quick Reply: Is the Tour Pak position adjustable?
