Tire wear
Old 07-16-2013 | 04:52 PM
Grey ghost's Avatar
Grey ghost
2nd Gear
Default Tire wear
I have a 2013 limited and the rear tire us cupping. I do a lot of riding at slow speeds with a lean angle needed to run a course on tarmac.
Old 07-16-2013 | 04:57 PM
CSMHOG's Avatar
CSMHOG
What tire pressure do you maintain and how many miles do you have on them?
Old 07-16-2013 | 04:59 PM
Grey ghost's Avatar
Grey ghost
2nd Gear
Default tire wear
11500 43 lbs check it every 2 or 3 weeks
Old 07-16-2013 | 05:09 PM
CSMHOG's Avatar
CSMHOG
Mine began to show slight cupping around the same mileage but I only maintained 41 lbs. I still got almost 20,000 miles out of the tire but switched to Michelin Commanders II.
On a previous bike the dealer replaced the front tire under warranty for the same issue, think the mileage was about the same.
Old 07-16-2013 | 06:17 PM
Grey ghost's Avatar
Grey ghost
2nd Gear
Thanks Boots I asked the dealer about and they had no answer only thought was tire pressure.
Old 07-17-2013 | 06:31 PM
8828alex's Avatar
8828alex
be careful when choosing tires , everyone will tell you this tire or that tire. i switched to michelins 2's and i dont like them at all. the video said they dont get caught in tar snakes or ruts . well these tires seem to seek the ruts and get caught in them and they seem to be a really hard tire. i too had cupping on the dunlop rear at around 11k and still rode them 3k more and i still felt confident with them. i have 75k HD riding experience and in my opinion the stock D407 & D408 dunlops are the way to go. aside from seeing the cupping can you feel anything different when banking into a turn with the cupped tires ? if not, stick with the devil you know instead of spending money on snake oil cure tires. i ride a 8k trip in may and a 3k trip after labor day and will finish the season with the commander 2's but next season they are coming off. good luck with your decision.
Old 07-18-2013 | 04:44 AM
grbrown's Avatar
grbrown
Tyre pressures are personal IMHO! You may be a little heavier than the rider weight Harley sets the pressures for, or ride in a way that transfers extra load to the rear briefly. It may be too late for this tyre, but add a couple of pounds. Most particularly if you ride 2-up quite often, the tyre pressures Harley recommend are too low, again IMHO.
Old 07-18-2013 | 05:55 AM
RK Joy's Avatar
RK Joy
I have been very happy with my stock Dunlops. Wear and handling have both been great. We have a lot of tar snakes in our area and they pose little trouble. My last bike had the 21 x 90 front and it was nasty on the snakes!
Old 07-18-2013 | 06:12 AM
collin's Avatar
collin
Old 07-18-2013 | 06:17 AM
slammed05fatty's Avatar
slammed05fatty
the rear dunlop just does that, my dealer actually covered the cupping under warrenty for about a year till corperate made them quit. my first on started at 3500 2nd started about 4500, still got over 10k out of each of the tires. i never had problem with the handling from it, got a tail whipping effect feeling in high speed curves but never seemed to let up traction. switched to the mich commandor 2 and have just over 3000 on it and no signs of cupping at all aand handles muh better overall. my 09 fatboy rear did it too but after only 1500 miles. id reccomend running it till it needs replaced and find a diff tire.
Quick Reply: Tire wear
