Ping, ping 4441 miles 2005 EG
Old 02-28-2007 | 03:47 PM
alwilson's Avatar
alwilson
Default Ping, ping 4441 miles 2005 EG
Hi Guys
Went on a 50 mile run this Satarday, when i stop at the red light everything was ok, then when i went to 2nd gear, i heard a ping come from under my seat, the oil is clean and where it need to be, today toke a ride for about 10 miles and no ping, do you guys think that everything is ok, also if it ping again do you think bad engine or what?
Thanks
Old 02-28-2007 | 03:56 PM
UltraKla$$ic's Avatar
UltraKla$$ic
Default RE: Ping, ping 4441 miles 2005 EG
ORIGINAL: alwilson
Hi Guys
Thanks
Just make us Louisiana boys proud and RIDE IT LIKE YOU STOLE IT!!!!!!!!!!!!!
That "ping" under the seat is prolly from the red beans and rice you ate for lunch.
Maybe bad gas, just ride it. Doesn't sound serious..........................yet.
Old 02-28-2007 | 04:01 PM
berettag's Avatar
berettag
I agree, probably gas, add a little Bean-O to your tank. Just kidding of course. You are using high octane gas aren't you?
Old 02-28-2007 | 04:18 PM
electraride2's Avatar
electraride2
heat shields tight ?exhaust flanges tight? I had a nut missing off my bracket under the seat.......did same thing
Old 02-28-2007 | 04:53 PM
choochoo's Avatar
choochoo
Well give a little more info?
How hot outside?
what octane gas?
stock or mods done etc.
Could be a exhaust pipe guard pinging a little but could be something else.
Engine pinging no matter how minor is NOT good.
Old 02-28-2007 | 05:00 PM
JeffSG's Avatar
JeffSG
Maybe it has an '07 motor in it? [:@]
Sorry, but I couldn't miss the opportunity to slide that in.
Good luck on finding the problem and ride safe,
Old 02-28-2007 | 05:21 PM
gunrunner's Avatar
gunrunner
No problem until you hear pong! Really, nobody can tell you anything, it could have been anything, ping is not a very good description to go on.
Old 02-28-2007 | 05:23 PM
alwilson's Avatar
alwilson
Hi choochoo
The outside temp: 72
the octane gas:93
no mods
SE Pipes
Thanks for your help
Old 02-28-2007 | 05:39 PM
berettag's Avatar
berettag
[sm=funnypostabove.gif] Now you gotta laugh at that one.
Old 02-28-2007 | 09:56 PM
choochoo's Avatar
choochoo
Well it's possible it was a one time thing.
Intermittent problems are tough to figure out.
But based on the info above you gave, doesn't seem it was hot enough
operating conditions to be a heat related issue at only 72 degrees.
And 93 octane should be plenty high enough, unless in the formulation (ethanol etc).
When you first come to a stop and sit a while (engine running) cylinder temps
will temporarily increase (called heat sinking in autos). And for the first few minutes after taking off until air circulation again cools motor down, the temporary higher cyclinder temps can cause a momentary pinging condition. Especially if when going from firstto second you shift a little soon and don't throttle up enough and load the engine a little.
For now I would ride as normal. Be aware of what you heard, keep an ear open.
Quick Reply: Ping, ping 4441 miles 2005 EG
