Checking tire pressure
I have a hose with pressure gauge and air valve attached. It has a 45* head. I do not come straight from the side at the stem. I pass it inside the brake disc with hose going towards axle hub until the chuck matches the angle of the stem. Make the connection hold it, look at the gauge if air is needed I just press the lever until I have the correct pressure. Not hard at all just had to figure out how to do it. Does take two hands.
Had the same experience. I bought the Harley air compressor. Works like a charm.
It has a pressure gauge and will pump the tires from your battery. Gives me peace of mind in case I had to use it on the road, too. Don't have to worry about carrying quarters and finding a gas station.
I can also do it in my garage when the rotors aren't hot...yeah, found that out the hard way. Or should I say, the burnt hand way.
Also has a flashlight, in case you don't have one and can't see the tires at night.
http://www.harley-davidson.com/store...sor-with-light
