Inner Fairing Uksays
RE: Inner Fairing Uksays
STOP; don't break anything. Go have a beer and read the service manual. I have an '04 EG and have had the switch cap off a dozen times and the only Torx were one on each side of the cap just below the handlebars. The ignition itself, at least what is removed in order to remove the fairing cap, has no bolts on the '04.
The ignition switch is held on by two Allen Head screws accessible from the front of the handlebars under the radio on the 06 Ultra.
I know this becauseI did remove my ignition switch when painting the inner fairing.
Once I removed the lock assembly from the Ignition switch, I couldn't get the upper cap off the ignition switch without damaging the insert under the lack assembly with the words on it (locked, off, ignition, accessory), so I removed the ignition swicth intact in the upper cap.
I just used a long "T" handle allen wrench. (and it was a real PIA)
