Which aftermarket Batwing fairing looks OEM?
Ive seen a lot of aftermarket batwing fairings , many of them dont fit with the same angles as a stock fairing. They are often tilted forward and dont look quite right to me.
The Reckless and Dead Center seem to be the better fitting batwing fairings that Ive seen.
It might also be the way the owners have mounted them as well?
I had a Memphis Shades on my Fatboy and I had to do some grinding and elongating the mounting slots to get it to lay back the way I thought it should to look like it belonged on the bike
After I raked my neck 10 degrees, the fairing was finally sitting at about the right angle, but I didn't like the way it fit with my aftermarket nacelle, so I sold the whole lot.
I think lots of guys buy detach fairings, thinking they'll be putting it on, and taking it off as the mood and weather fits. However, the reality is, (if you're like most guys), you'll mount up the fairing, and almost never remove it. I liked having tunes with me, and it made long rides much more comfortable. After awhile, mine almost never came off.
But I wanted more. I wanted the fairing mounted gauges, and I wanted handlebar mounted radio controls. I finally decided that I wasn't going to ever be really happy with an aftermarket fairing, and converted my bike to an OEM Road Glide fairing.
FN...think of it this way, in it's simplist form. Take a stock RK windshield. Now take a stock outer fairing and a stock inner fairing and clamshell them on either side of the windshield. Drill three holes in the windshield for which to pass the bolts that attach the two outer pieces together and there you go!
If you are inclined to do your own fabrication, the job is basically a lot of cutting, trimming and fitting the three pieces together. If you want more specific info and pics, PM me.
And Boogaloodude, I think a lot of guys do leave the fairing on much of the time. But I got to admit I couldn't wait to get mine off after my recent 2,900 mile tour. I use the fairing for long touring because from Minnesota we really don't have much of a choice but to ride through 1 or 2 days of boring prairie to get anywhere, and that is where I want tunes. But other than that I much prefer the windshield.
I know this thread is a little old but it is exactly what i have been looking for. i decided to add a fairing to my heritage and decided to go with an OEM street glide setup due to the versatility of the inner fairing. I am unsure how to get it setup right ie: what to cut where to cut so on. Pumba11, i tried to PM you but i havent posted enough for that privilege i would guess(i like to get on here and read but have a hard time contributing). Any advise or tips are greatly appreciated.
I like the looks of the dead center and the dragon fly fairings. The only things that holds me back on an aftermarket fairing are, it has to be ABS not fiberglass, and i also like the idea of fairing mounted gauges. However, my current setup is a 2000 heritage classic with mini apes and i don't think an OEM street glide inner will fit. Are there any aftermarket options that offer gauges?
