Interstate Touring Bikes
well, not really, the chassis, drivetrain etc is all the same model to model ( within same model year). some have lowered rear by 1", that would be the only diff in suspension
the fairing design is HUGE at that kinda speed. the batwing fairing will unload the front end at high speed, traction is reduced...this can get tricky in sudden crosswind gusts.
the fork mounted fairing can turn gusts to "steering input", and traction is maybe not optimal because of the fairing "lift".
klockworks has claimed their windscreen helps counteract this- I dunno.
a sharknose may be smarter.
the frame mounted fairing reacts very differently to crosswinds/gust and i don't think the fairing unloads the front like the batwing--- and I have ridden those speeds sustained on one
( I ride a batwing- a rarely creep over 80 and I like other aspects of the batwing over the shark.
at this point I've figured out that fewer fuel stops make for a quicker overall trip, so a lower speed may get you there quicker)
Mike
Mike
I'd go with a Roadglide, if only for the gas mileage. I switched my previous bike from a batwing to a sharknose & gained 2-3 mpg on average with no other changes. I also gained 5-8 mph top speed, the batwing gives good protection from the elements, but as for aero it's a big barn door. I'm guessing at 90+ you'll gain at least 5 mpg.
There are certainly advantages to the Shark. Not having the weight of the fairing on the forks is the biggest one. The problem with it is that it's so far out front, the airflow around it converges right where your passenger's head is, causing a ton of buffeting. This can be somewhat mitigated with various baffles and windshields, but your backseater will never have the same serene ride (s)he gets on a Batwing.
We're it not for the fact that I ride 2-up so often, I would have bought a Roadie, no doubt about it.
