ECM:P2138 TPS correlation error,after getting rained on
Yes,I posted about it a while ago. It had happend to me again, I went right to the splice my HDealer did and peeled back the sheath and took the tape off the ugly splice they did and found that they had only spliced 3 of the 6 wires running from the grip!!!! So while I was at it I found some better looking nylon sleeve material and pulled all the wiring through it after splicing the last 3 wires they didn't.Now they're all the same length, Only one was broken (you have to feel for it because the wire is broken/shorting inside its' insulation) Anyways it's all good now.
From a similar thread,
https://www.hdforums.com/forum/newre...ply&p=11695890
Woot Woot, got a call today that the shop found the broken wire in the harness that has been eluding them. The pesky wire that broke is in the harness on the right side of the bike near where the front of the gas tank bolts to the frame. There is a harness support bracket riveted to the frame and the broken wire was in that area. Rode the bike for a couple of hours tonight, the performance is back to how it was pre problem and no more codes or check engine light.
It is like I got an old friend back that had been away for too long.
I was busy editing/adding stuff to last post.
