View Poll Results: Which have you upgrade to and why?
Ohlins
21
21.00%
Progresive
48
48.00%
JRI
21
21.00%
Air ride of some sort
10.00%
Voters: 100. You may not vote on this poll
Which rear shocks
I too went with the 940's.
Night and day different then the stock HD 12" air shocks.
However, I have upgraded again to the Ohlins 2-2's, and
they are NIGHT and DAY different and BETTER then the Progressive 940's!!!
Happy 4th of July!
YB
I started with Ricor intiminators in the front and then wondered what happened to the back. I then went with Ricor shocks in the back and went what happened to the front. The rear shocks are good. the front jumps up on a bump and the rear just taps you to let you know they are there.
Now if I could actually get the front and back to ride the same...
I started with the stock 12" SG shocks, went to Progressive 940's for 25,000 miles (used lighter springs), then JRI-B for 1300 miles, then I changed the oil in some HD 13" air ride shocks and got the best ride yet. Went with 11 oz of Amsoil 10w suspension fluid and 8 lbs of air. Awesome ride.
Could you give more details on this, how much do you weigh? 2 up or solo only? If I can get a real improvement on my Kings 13" shocks just from the oil I'm all over it. Thanks.
I cant believe more guys are not jumping on this post. WI Bob you went from JRI-B to HD stock 13" air shocks and got a smoother ride by just changing the shock oil? I have seen Threads on changing the shock oil for a smoother ride but I never dreamed it would be close to the JRI. Are you sure you had the JRI adjusted right.
can you still feel that 2in in road diff will going over a bridge
