Which oil to use for lubricating throttle and clutch cables?
Old 07-02-2013 | 06:57 PM
steelerdude1's Avatar
steelerdude1
Harley Lube - clear oil has the needle to make things easy
http://www.harley-davidson.com/gma/g...bmLocale=en_ca
Old 07-02-2013 | 06:58 PM
soft 02's Avatar
soft 02
With a teflon coated cable-none.
Old 07-02-2013 | 07:00 PM
skully1200's Avatar
skully1200
Last year I used Dri Slide on my throttle cables and it worked okay for a while then started to get sticky. I also managed to make quite a mess. This year I used PJ1 cable lube in an aerosol can and a clamp on tool. Flushed the old gunk out of the cables and now they operating much more smoothly. So far, anyway. I did put graphite on the bar inside of the throttle grip and also on the pivot pin for the clutch lever.
Old 07-02-2013 | 07:09 PM
perki48's Avatar
perki48
Originally Posted by MNPGRider
Although this goes against conventional wisdom, check your owner's manual and service manual. I bet you will find no place where it tells you to lubricate the clutch cable. Throttle cables yes, and in fact detailed instructions are in the service manual.
I, too, was told, that some lubricants can affect the interior of the clutch cable housing.
I followed your advice:
From 07' Wideglide manual
CAUTION
The clutch control cable must be oiled and adjuster peri-
odicall to compensate for lining wear.
Notice the word "oiled".
Old 07-02-2013 | 07:58 PM
Geoff's Avatar
Geoff
Dri-slide
Old 07-02-2013 | 09:35 PM
MNPGRider's Avatar
MNPGRider
CAUTION
Thanks for your post. I again checked all three places the clutch is mentioned in the index in my service manual, and there is no mention of lube on the clutch cable. (06 Ultra)
Old 07-02-2013 | 10:15 PM
perki48's Avatar
perki48
I also looked in my service manual and can not find it mentioned there. Its only mentioned the one time in my owners manual.....................By the way, I envy you your Triumphs.
Old 07-03-2013 | 12:25 AM
lp77's Avatar
lp77
many thanks for your advice. Finally decided I'm going to use the Harley Lube 94968-09.Can order it online here in the Netherlands. Might be a bit expensive but won't use a lot.
Old 07-03-2013 | 05:24 AM
Barrenmug's Avatar
Barrenmug
Liquid Wrench Silicone Spray.
UmpOne
General Topics/Tech Tips
21
02-22-2017 09:35 AM
oldncrzy
03-27-2010 10:45 PM
99octane
07-20-2009 09:52 AM
HB
02-11-2009 03:49 PM
dforeid
08-17-2006 10:05 PM
Quick Reply: Which oil to use for lubricating throttle and clutch cables?
