shifter, shaft spline
Any idea where I can order one besides j p cycles or a dealer?
To clarify, I need the spline with teeth that the shifter slides onto and the tightens on.
not the shifter itself or the linkage.
I cant see paying 90$ for one, there has to be a way to buy a used one.
EBay didn't show any or a general internet search so I thought I would check with you guys
Lump
Lump
I need the spline that the shifter mounts on, it has teeth and you put your heel and or toe shifter on this spline.
Mine is partially stripped so I can not use both shifters, I need to replace it and the dealer and parts cat want $100 for it.
if I have to pay that so be it, but I'm hoping to find a used dealer online I can get it from for much less.
Lump
Lump
I was looking at a different part number and my Indy looked it up while I was there having a tire mounted and like I sad wanted $89, I fond a couple online for 75$
Then I got the other part number, verified it was he same pat and was $20 shipped, I'll call my local dealer tomorrow.and see what they say.
Thanks against .
Lump
Thanks against .
Lump
